removing all coolant from running through firewall?
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
since i have yanked my ac AND heater.. i dont need the coolant lines running into the firewall anymore, so whhich hoses do i need to connect together to bypass the firewall? thanks
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
umm, teh only lines on the firewall IS the heater core
so if you pulled your heater, theres nothing for the lines to attach to anyway.
Car: 1988 GTA
Engine: 5.7L/L98
Ditto not sure what your asking.
On a side note, you yanked your heater and you live in placerville? Guess you only drive in the summer. My heater was down for almost a year before I got around to replacing my heater core, it was miserable in the winter, the cold wasn't as bad as not being able to keep the windows defrosted.
I think he is trying to ask what to do with the lines that dont connect to the firewall anymore. They will be gushing coolant if you dont do something. I would say, just connect some heater hose from the one on the pump to the intake. Should bypass just fine.
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Stopped at a $ store, bought a steak knife, cut the hose from the heater core and routed it to the manifold. And cleaned up the warm green pool i had on the floor. Ill fix it before winter.
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Leave the two holes open on the firewall, put a plug in where the coolant ran to the intake and block off the nipple on the raditor somehow. Other then that, thats it
eightsixseven
Dec 16, 2024 01:50 PM
