Battery dead AGAIN
Old Jul 19, 2004 | 08:37 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Battery dead AGAIN
I just replaced my optima abut 2 weeks ago and it is doing the exact same thing as the old one. When the key is on the volts are in the read. When im idleing in traffic the guage goes down near the read. The alternator is new along with the battery. Could the alternator be causing this problem? When im driving my volts are at 13 which is normal ever since i bought the car. And at times the volts will drop a little past 13 at idle in traffic..
Any one have any ideas why this is happening? I have checked all my connections and they are in perfect condition.
Old Jul 20, 2004 | 12:15 AM
sellmanb's Avatar
Car: '86 Berlinetta
you have checked the connection that goes from your block back to your battery then I'm guessing? A new alternator, and new battery and your battery goes dead now. I can only assume that something is not connected correctly, or there is too much grease or grime or whatever at a connection causing it not to get electricity back into the battery.
Old Jul 20, 2004 | 06:37 AM
contactpatch's Avatar
Engine: sbc 350
When the car is running, the voltage across the
batt should be 13.8 to 14 or so.
13.0, too low.
Old Jul 20, 2004 | 10:23 AM
FAST RS's Avatar
If i put my stock crank pully back in it will run at 14 but since i have a smaller crank pully it has less rotating mass. How ever i didnt have to replace battarys all the time when i first put it on a few years back it just seems lately that it has been doing this.
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
92projectcamaro
Sep 29, 2015 07:07 PM
drumstixer
Sep 29, 2015 03:02 PM
raymondandretti
Sep 27, 2015 06:43 PM
