high voltage question within
Old Jul 20, 2004 | 03:16 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Sould i be worried if while i am driving around and look at my battery voltage gauge and i see the needle up in the red at 18 but then when i am setting at a red light it drops down to normal around 13 -14 v.... Is this a common thing? Every other car i can remember driving the needle stays put.
Old Jul 20, 2004 | 03:38 PM
Conv389drv's Avatar
Well, overcharging isn't good, it'll burn out the battery over time. Maybe the alternator's voltage regulator crapped out. You may want to get it tested.
Old Jul 20, 2004 | 03:47 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If the battery and alternator check out good, you might look at replacing the voltmeter in the instrument cluster.
Old Jul 20, 2004 | 08:47 PM
Car: 92'Camaro RS
Engine: a loud one
maybe i'll check the alternator, battery is a brand new optima gel battery. How to i go about testing the alternator?..Just check the voltage?
Old Jul 20, 2004 | 10:00 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Take it to an auto parts store and they will test it for you. It is normally a free service that they provide to customers.
Old Jul 20, 2004 | 10:09 PM
ljnowell's Avatar
you could check the voltage yourself, wont hurt anything. If you take it to the parts store many of them give it a free bench test. THen you know for sure what is up.
CORV3TT3
Aug 23, 2015 11:26 AM
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
