Top radiator hose collaps
Old Apr 18, 2001 | 11:36 AM
snoozeyaloose85's Avatar
I have a 85 trans am 305 tpi my question is. When I give it gas the top radiator hose will collaps and then return to normal. I heard of the bottum one but the top do I need a spring in the top one to or is it something else
Old Apr 18, 2001 | 03:02 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
You need a coolant recovery tank. It will suck fluid out of the tank to keep the hose from going flat. See if you can find one with a spring inside also (a top rad hose, not coolant recovery)
[This message has been edited by jcb999 (edited April 18, 2001).]
Old Apr 18, 2001 | 04:00 PM
Thanks for the reply but I have a recovery tank. Could it be the thermostat isn't opening up far enough just a guess. But it doesn't overheat it just collapses and returns to normal maybe it an old hose. I'm gonna try to find a spring for it any way.
1992 Trans Am
May 10, 2023 07:19 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 20, 2015 12:29 AM
Zachattack0925
Aug 12, 2015 09:52 PM
