OiL PRESSURE QUESTION!!!!!!
Old Apr 18, 2001 | 11:35 AM
smokntires's Avatar
Ok I just swapped a bigger cam and heads into my 83 camaro and now the oil press fluctuates With a push of the throttle, the motor is not very old less than 7 grand on the motor and parts. The it goes from insanly high to just below average for stock. The car has no computer or emmisons controlls on it. This is something I have not run accross in my past experiences building cars. The motor has only one small oil leak at the front of the pan. Thanks for the help guys
save your lungs smoke an import!
Old Apr 18, 2001 | 05:40 PM
ede's Avatar
ede
i'd suspect a bad sender, check it out, or just replace it. you might also wamt to check with a mechanical gauge, the factory set up isn't known for being accurate.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
