External Coil or Coil in Cap Dist ?
Old Jul 21, 2004 | 07:52 PM
jasonrmorrow's Avatar
I'm using a painless harness that calls for the small cap computer controlled distributor, so it has the two seperate connections, i have heard that the large cap or coil in cap designs last longer and are more desirable, i have a buddy who works at a junkyard, i have a small cap in my hand, no coil though, but i asked him to keep looking for a large cap, is the harness adaptable, i think they are the same wires just different connectors correct ?? Which should i go for ?? Thanks.
Old Jul 23, 2004 | 06:29 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I have an external coil, so I'm partial to it- but I don't know otherwise. What I can say tho, is if you ever plan to get an aftermarket non-direct-fit coil, if you have a coil-in-cap distributor, then you need to cover that hole up in the dist cap. (Example would be putting an MSD 6AL box on with an MSD Blaster 2 coil)
With an external coil setup, if you change to an aftermarket coil, you don't have to worry about the cap.
Old Jul 23, 2004 | 06:33 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
psssttt.... look here....
https://www.thirdgen.org/techbb2/sho...hreadid=251525
Now I ask, why?!?
pjsparts
Oct 29, 2025 06:39 PM
earlpote
Sep 12, 2015 11:55 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Jlanz55
Sep 6, 2015 03:05 PM
