Only one v-belt good enough for WP and Crank?
Old Jul 22, 2004 | 06:50 PM
Balael6's Avatar
Car: 1988 Formula
Engine: Twin Turbo .60/.63 305
Transmission: T-5 5 speed
I switched to a vbelt setup on my firebird, with only the water pump(2 groove), Crank (2groove) and alternator, 1 groove, I'm wondering, will only one belt for the crank, water pump, and alternator be good enough?
Has anyone else ran with just one belt between water pump, and crank?
Thanks guys.
pj
Old Jul 22, 2004 | 06:54 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's how cars came from the factory for many many decades. So I'm sure it will be fine.
Old Jul 22, 2004 | 06:56 PM
Balael6's Avatar
Car: 1988 Formula
Ok just checking, the extra spot looks stupid is all.
Old Jul 22, 2004 | 08:25 PM
ckjoshz28's Avatar
isn't the other spot for power steering and maybe a/c?
Old Jul 22, 2004 | 08:48 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
So, you're not running a power steering pump then?
And yes a single belt is fine.
Old Jul 22, 2004 | 10:04 PM
Balael6's Avatar
Car: 1988 Formula
Alright sweet, thanks for the answers guys.
pj
Old Jul 23, 2004 | 01:50 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
My '83 has the stock V-belt setup, and its got one belt for Alt/WPump/Crank and one for PS/Crank...
Old Jul 23, 2004 | 10:08 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Only one v-belt good enough for WP and Crank?
Thanks guys.
pj
What I like to do with this type of setup is to run another belt between the crank and water pump. It looks better and gives another layer of protection if the alternator belt is thrown.
In order to get this belt in place loosen the water pump pulley enough to slip the belt on, then tighten the bolts. The belt doesn't need to be real tight, but also shouldn't be too tight.
RBob.
Old Jul 23, 2004 | 10:51 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
a few years ago, when i had my 82, it had 2 V belts... a crank, alt and waterpump belt, and an crank to PS pump belt.
well one day im driving, and i see the the temp rising FAST. like scary fast. i also notice the voltage is a lil low. i pull over and look underhood. ofcourse, its late dusk and im in the middle of nowhere.
no water pump belt. i still donno what happened. alt was tight, belt wasnt old, and ive never thrown a belt before or since.
in anycase, i took off the power steering belt and found that it ALMOST fit between the waterpump and crank... so i wedged it as close as i could, and cranked the motor over so the belt popped on.
was a pain to drive with no power steering, and with the headlights on killing the battery, i JUST made it back.. but the 2nd belt worked for me.
Old Jul 23, 2004 | 12:47 PM
Balael6's Avatar
Car: 1988 Formula
WHen using the belt on the water pump and the crank pulley, what size belt did you use?
PJ
Old Jul 23, 2004 | 05:59 PM
Air_Adam's Avatar
PJ
Just go to a parts store and look up old chevy stuff... like early '70s trucks and stuff. They usually had one just for the wp and crank.
Old Jul 23, 2004 | 06:36 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That's the only reason I like my V-belt setup; the water pump will always spin. I keep an old alternator belt under my driver's seat in case I ever need it. Power steering I could do without, the a/c's already gone, but I'd have to have an alternator!
Old Jul 23, 2004 | 06:37 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
7445, 7450, 15450
Caspar
Jun 19, 2016 11:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
Winchester1094
Aug 18, 2015 10:23 AM
