one piece seal engine block whoes....Help!!!
Old Apr 16, 2001 | 08:45 PM
poncho9789's Avatar
I reciently bought a 89 gta. The man I bought it from thought that the head gasket had blown. Upon teardown of the engine I found that the block was cracked in the no.4 cylinder. The block has one piece seal and 4-bolt mains. Is this a hi-pervormance block or are all the one piece blocks 4 bolt. I have concidered sleveing the block,but would rather have a different block. Also what would be a fair price for a one piece rear seal 4-bolt block and 2bolt. If you can please help.
Old Apr 16, 2001 | 09:03 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
used around 250 to 350 for a good one, the higher being a 4 bolt. 4 bolt blocks are cheapest from 8600 gvw and over truck engines. (8600 gvw and over being the 8 lug 3/4 ton trucks and bigger series).i don't remember what year the corvette began using 4 bolt blocks again, but they are nice too, but expensive. a 2 bolt would work fine for pretty much any normal use.
Old Apr 17, 2001 | 03:04 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
4 bolt blocks arent even necessary until you are getting up around 600+ hp. 2 bolts are a dime a dozen.
85 IROC 350 11:1keith blacks,.555lift erson roller cam,1.5 crane roller rockers,edelbrock intake,holley 4150 750dbl pumper, nitrous oxide,full length heddman headers,true dual exhaust, 11"stall converter, 700R4, 3.73 locker
Old Apr 17, 2001 | 03:29 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
It's not the HP, it's the RPMs you need to watch out for.
Call around to some junk yards looking for a truck or van motor. If you pull it, you can probably find one for around $150-$200. The yards usualy consider them cores so they don't kill you for them. Just bring a list of casting numbers.
Old Apr 19, 2001 | 04:35 PM
poncho9789's Avatar
thanks guys I let my fingers do the walking and found a block out of a 88 3/4 ton work truck for $225 w/the heads. The guy did hot want to part the motor, but it is still not a bad price.
1992 Trans Am
May 10, 2023 07:19 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
