How much do the impact beams effect safety?
Old Jul 23, 2004 | 02:11 AM
25THRSS's Avatar
How big of a role do the front and rear impact beams play in the event of a crash? I am thinking about removing them for weight savings, but I obviously don't want to die in a crash. Would it be crazy to remove them on a daily driver?
Old Jul 23, 2004 | 03:11 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
For me, these fall under the category of "The factory must have put them there for a reason."
On a street car, if it were MY street car, I would leave anything that is there for safety, well alone.
Is this a car that is a DD but goes to the strip occasionally? If so, I'm sure that weight can be lost elsewhere before the impact beams are tampered with, unless the car is already gutted and you are sitting on a plastic crate.
Old Jul 23, 2004 | 05:43 AM
ede's Avatar
ede
yeah for sure you can figure GM didn't take the time, money, or effort to put them there if they're just extra weight.
Old Aug 7, 2004 | 01:15 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
I wouldn't remove them on anything other then a race car. I removed them on a car and the front weighed 37lbs and I forgot to weigh the rear but I would guess 25-30lbs.
Well, Murphy's Law kicked in 3 days later and my dad backed into the LF of the car when his rear window was foggy. Wrinkled the fender bad and bent the hood latch area up a little.
It's an easy way to kill 60-65 lbs, but I wouldn't on a DD.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jovibuilt
Oct 18, 2015 08:12 PM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Damon
Sep 26, 2015 04:29 PM
