Low HP for these Mods??
Old Aug 7, 2004 | 12:49 AM
turbobike's Avatar
Car: 87 WS6 Firebird
87 305 TPI, 5-sp 3.43axle
Mods:
A)pocket Ported heads,
B)Cranecam ,.429 in .452 ex 204 and 214 lift @,050"
c)Hooker headers w/ 3" pipe and cat exhaust.
D)accel coil, plugs and wires
E)Modifyed intake MAF sensor and KN Filter (no-stock air box)
F)Chip from EFImike on these boards
G) New KS, O2 sensor
H) 48psi fuel pressure w/ hose diconected
Rear wheel hp is 204HP 277 Tq @ 3800rpm, down hill from there 4400rpm is 190hp 225tq by 5000 it's 155 and 170tq.....
Is this low? any Ideas
Old Aug 7, 2004 | 01:36 AM
sellmanb's Avatar
Car: '86 Berlinetta
Re: Low HP for these Mods??
Mods:
dual exhaust really wakes up the car, but most of your mods are related to getting the car breathing better, that's mostly torque there... which does sort of seem a little low, but when you face the reality that 305s dont respond to mods as well as 350s then you can see that those numbers match up about right.
Congradulations on hitting the 200hp marker but modfest must continue. Or a 350 I need to get a 350 still, bleh, damn you paychecks for being so small -shakes fist at paychecks-
Old Aug 7, 2004 | 01:44 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Those really aren't major mods. Its pretty much just a stock 305 with a slightly bigger cam and exhaust. Those numbers are about right for TPI. If you throw a carb on there you would see a major increase in HP.
You will also have to get a chip or burn one yourself to see some optimum results from those minor mods.
Old Aug 7, 2004 | 01:50 AM
sellmanb's Avatar
Car: '86 Berlinetta
Be nice ME Leigh lol. He did get a chipped burned it seems. You have a great starting ground for adding more power now man. Keep up the good work.
Old Aug 7, 2004 | 07:43 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
With what you added (not much in the power mods) the numbers are about right for the RWHP which is about 235 HP at the flywheel which is not bad.
Old Aug 7, 2004 | 12:59 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
I'd say go with a much bigger cam, like the Lt4 hot cam(but with 1.5 roller rockers instead of the adv. 1.6 which will give you about .495 lift) Then get a high flow tpi setup such as the stealthram or maybe even the edelbrocke setup. Then with another custom chip youll see a big increase. Also you would benefit from bigger valves in those heads if you dont already have them. Good Luck.
Old Aug 7, 2004 | 01:18 PM
DJP87Z28's Avatar
For that amount of work and money, just put a 350 in.
Old Aug 7, 2004 | 01:25 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Yeah he could do that,but if the motor he has now is in really good running order then it would almost be a waste of money to buy a 350. Trust me I am not a big fan of hopping up 305's, mine had less than 90,000 on it and I ditched for a 350. I am just saying it sounds like he wants to stick with it since hes already done a good amount of work to it, and its a real hassle to get a 350, and those mods cost less than one. just my
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
db057
Apr 28, 2019 07:45 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
amcnellis
Sep 16, 2015 04:16 PM
adelane
Sep 9, 2015 08:51 PM
