Speedometer and gearing question
Old Apr 19, 2001 | 06:37 AM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
My 92 RS has a electrical speedometer, right?
So if I were to buy a new speedometer It would have to be electronic? a electronic one is $199 and a mechanical one is $112. Would it be worth changing it to mechanical and can it be done?
Next question on gearing, if I change from a 3.08 to 3.73 do I need to change the speedo gears? or VSS? Does tire hight play a role in that too?
Thank You,
Dave
Old Apr 19, 2001 | 07:58 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
1) Why would you want to change the speedo??
2) If you change gears, you will need to re-calibrate the speedo. If the ECM controls the speedo, it will need to be re-calibrated. ( I'm not sure on the early electronic ones, I would call a speedo shop.)
3) Yes.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
Old Apr 19, 2001 | 11:06 AM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
Maybe I should of worded that different. I want to change out my speedometer to a Auto Meter ultra-lite, they offer a mechanical or electronical one. Which one do I need?
Old Apr 19, 2001 | 09:12 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
I'm not familliar with the autometer gauges, I would assume that if you have an electronic speedo, I would stick with the electronic autometer.
Would make the swap easier I would think.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
Old Apr 20, 2001 | 01:37 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Since you have 3.08 gears, I think you have a 5-speed? Keep the electronic speedo, its worth it. For a 5-speed and 3.73 gears, you need a 7 tooth and a 21 tooth speedo gears.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
