Choosing a cam for my Vortec 355
Old Jul 23, 2004 | 06:01 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
Hey guys, time to go cam shopping again since I trashed a pair of comp cams. I'm looking to purchase another brand of cam for my vortec 355. I'm hoping to push it into the low 13s with a new rollar hyd. I'm looking at something around 500 lift and 230 dur?
Crane has the HR 276 2S (.488/.509 214/222)
which im leaning towards,
Anyone else using a non comp cam in their vortec setups? I'd love to see what others are running and what times they are getting.
Old Jul 24, 2004 | 04:59 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Used a lowly Woverine blue racer (Crane) in my vortec motor. very simular to yours.
It ran 13.40's @104.5 with a stock 700r4 and 2200stall
later ran 13.00's @103.5 with a th350and 3500stall
high vacuum, good idle easy on valvetrain parts and fuel.
You can find the specs here
Worked very nicely.
If you want a hyd flat tappet cam thats easy to live with this one is a good one.
Old Jul 24, 2004 | 10:45 PM
1tinindian's Avatar
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
Mines in my sig, sorry, no times though
Old Jul 24, 2004 | 11:48 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I guess a big question is: does the cam have to fit under the factory spring heights? Because i plan on using a Lunati Bracket Master II cam (p/n 00010) with a set of Vortecs that are modified for lift.
Old Jul 25, 2004 | 10:08 PM
rangelec's Avatar
GM HOT cam and kit. I get 25+mpg with my 86 and it will run 13's easy. Great idle and runs real good.
Old Jul 26, 2004 | 07:21 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Crane
Old Jul 26, 2004 | 09:52 PM
rangelec's Avatar
I believe the specs on the HOT cam are .525 lift on int and exh-duration @ .050 is 218 int 228 exh-do not remember what the lobe centers are right off the top of my head. These specs are with 1.6 rockers. One of the magazines did a dyno test (if you can believe them) with vortec heads and the HOT cam kit and came up with 407 hp and 427 ft. lb.-not too shabby for a 9.5:1 350. Not sure what the pricing on the kit is right now but should be around $500 including the roller rockers. This is the same cam that comes in the ZZ430 Here is a link to SDPC2000 website-$499.95 complete. http://www.sdpc2000.com/cart.asp?act...d=993&pid=1900
Old Jul 27, 2004 | 01:03 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
Thanks guys, I have springs on my heads that will support up to .550 lift and I've already got 1.6 rockers so a cam in the .490 range is about my limit.
How much are those GM HOT cams worth?
are you sure .525 is it's lift with 1.6 rockers?
if so that looks like a good cam
I also found a lunati rollar that looks attractive
.478/.480 with 227/234 duration
with 1.6's that would put me at just over .510 lift which is still safe
Old Jul 27, 2004 | 01:06 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Yes, .525 is the lift with 1.6 ratio rockers.
Old Jul 27, 2004 | 10:33 PM
rangelec's Avatar
I happen to have an extra HOT cam that has never been run-$150 shipped to your door. My buddy was going to buy it but he backed out.
Old Jul 28, 2004 | 02:34 AM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
13.10 @105mph and it wanted more fuel but the edelbrock 750 wasn;t giving it so now i am tuning a 750 double pumper for her.. good luck with the vortecs man i absolutly love them..
Old Jan 29, 2024 | 05:14 PM
Cary I. Fowler's Avatar
Re: Choosing a cam for my Vortec 355
thats right
Old Jan 29, 2024 | 05:15 PM
I just seen this and I know its a long time ago BUT where is that cam now?
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Billy Decker
Sep 4, 2015 03:46 PM
Strick1
Sep 4, 2015 07:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
