car stinks after o2 sensor change
Old Jul 24, 2004 | 02:01 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Like it says, after I changed my o2 sensor (bosch), my exhaust smells richer. Not like eggs...but like carbon monoxide.
Is it recommended that I disconnect the battery terminal to reset the computer or what?
Could it be somethign related?
Old Jul 24, 2004 | 03:11 PM
MasterEvilAce's Avatar
carbon monoxide is odorless
Old Jul 24, 2004 | 03:13 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Old Jul 24, 2004 | 04:46 PM
Vader's Avatar
Yes. Completely clear the ECM, then wait for the BLM tables to regenerate with the new, good data from the P² sensor.
Old Jul 24, 2004 | 04:48 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
You dont need to do anything to "reset" your ecm. It should function properly after the change. Why did you change the o2 to begin with?
Old Jul 24, 2004 | 09:07 PM
why did I change it? Car as 170k mi and I've driven it for 50k of those. Don't know when it was changed if ever. Making frequent road trips this summer and making sure everything is tuned up and working as it should.
Oops....CO is odorless. Brainfart.
I'm sure the point was not lost on you though.
Thanks vader.
Old Jul 24, 2004 | 09:54 PM
Vader's Avatar
Dank is right. You don't have to do anything. The integrator will act on the new sensor data and write new (correct) data tables a little at a time, slowly but eventually skewing the tables downward (lean) until they are correct.
However, if you are as impatient as I am, you'll clear the ECM amd force the integrator to start constructing new data tables right away - Well, as soon as the ECM goes to closed loop, anyway.
Old Jul 25, 2004 | 11:40 AM
Ok. Now I understand. I appreciate your input. Thanks.
92firebirdguy
Sep 1, 2016 07:53 AM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
m00n420
Sep 11, 2015 02:39 PM
FormulasOnly
Sep 10, 2015 09:07 PM
