Big Block Accessory Question
Old Apr 20, 2001 | 03:19 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I know big block cars except the Corvette used the short neck water pump up to 68, and the long pump from 69 on. Did the 68 and 69 blocks and heads have the accessory mounting holes in the same locations?
Old Apr 20, 2001 | 07:09 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Short neck water pumps didn't have accessory mount holes.
Old Apr 20, 2001 | 12:34 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's not the holes on the pump I'm worried about, it's the ones on the heads.
Old Apr 20, 2001 | 08:46 PM
AlkyIROC's Avatar
Car: 87 IROC L98
To my knowledge all big blocks from 65 to present have accessory bolt holes in the heads and in the same locations.
Up to 1970 they used the large spark plugs with the gasket washer. Somewhere in 1970 they changed to the tapered seat plugs.
midge54
Dec 27, 2019 04:14 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
