NEW wires foil on plug wire heat protectors sparking?
Old Jul 25, 2004 | 01:18 PM
AUTOGON350's Avatar
Car: 93 S10 blazer
I just installed a set of taylor spiro pro 8mm wires. I used those plug wire heat sleeves that have the foil outer coating on them. There are sparks jumping from the foil to the headers and from the foil on one wire to the foil on the others close by. In some places the wires arc to closeby metal. Its not enough spark to shock me but it is visible. Is this affecting the operation of the engine or is it just exess voltage bleeding off. The engine doesnt seem to have a miss. Are these bad wires or is a little sparking common. This happened on the first startup with the new wires.
Thanks for any info
Old Jun 18, 2005 | 01:16 AM
glintscollide's Avatar
damn im having the same problem.Didnt put any heat sleeve on or anything but bought new pluggs put em on and the sum bitch is still sparking.Driving me crazy if u find out anything give me a holler.
Jason
Old Jun 19, 2005 | 02:02 PM
AUTOGON350's Avatar
Car: 93 S10 blazer
I never really got to the bottom of it. I put that dielectric lube that they sell in the little squeez packet on the plugs and cap terminals and it helped. Other than that I just put the plug wires as far away from metal stuff as I could. The sparking really does not seem to affect the engine so I just live with it. The sparks are small not the big ones that make a cracking sound. I guess the aftermarket HEI is just that powerful.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
djmarch
Aug 19, 2015 12:07 PM
Bryan F
Aug 18, 2015 02:28 PM
