Basic timing question
Old Jul 25, 2004 | 01:19 PM
md65000's Avatar
Car: 1989 Camaro IROC-Z
I was trying to diagnose some surging and cold idling problems on my car. I checked the timing (89 IROCz 5.7 TPI) and it was right at 6 degress with the EST wire disconnected. Then I reconnected the wire to see if it was advancing properly and to my surprise the timing mark went about an inch off the tab - and that was still at idle without any reving. I also noticed a change in the exhaust odor - I think it smelled a littler richer.
So my "basic timing question" is: What should the timing normally be at idle but with the EST wire still connected?
Thanks!
Old Jul 26, 2004 | 10:23 PM
Conv389drv's Avatar
Try a dial-back timing light (Craftsman makes one, sold at Sears) to determine exactly how many degrees of advance the car has at idle with the plug connected.
I'd expect the computer to advance the timing somewhat, but it shouldn't be 36 degrees or something high like that.
Old Jul 27, 2004 | 10:12 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Idle timing with the EST plugged in could easily be 20-25 degrees, but not much over that. If it went off the tab or timing marks then something is wrong somewhere....
Old Jul 27, 2004 | 01:28 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
actually that sounds pretty normal to me. when I check timing with the computer connected, first of all the car idles at 7-800 rpm and yes the timing is well off the tab.
When I disconnect the est it goes back to 6up.
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
