how do you change the rear main seal in a 87 and later one piece seal?
Old Jul 25, 2004 | 02:45 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
my motor is leaking all over and i wana change all the gaskets at once
i just not sure how to change the rear main seal
thanks guys
joe
Old Jul 25, 2004 | 04:02 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
You need to either pull the transmission, or the engine. Usually the tranny's easiest. Then just pull the seal and tap the new one in. If you're putting alot of new gaskets(such as oil pan) on your motor maybe pullin the engine would be easier.
Old Jul 25, 2004 | 05:29 PM
jerflash's Avatar
i was thinking the same thing i just hate taking the headers on and off
if i do pull it i will change the cam andport the heads and all
but i dont have another car to drive around right now because my 02 is broke as well
Old Jul 26, 2004 | 04:23 AM
ede's Avatar
ede
think i'd find the source of the leak instead of blindly swapping out gaskets. there's a good chance it'll still be leaking from the same place it was after you make the gasket swap.
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reborn756
Sep 4, 2015 03:42 AM
Exxon Limited
Aug 9, 2015 08:13 PM
