Has my Jegs remote starter solenoid gone bad?
Old Jun 20, 2004 | 06:20 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
Car has been starting when it feels like. Has a Jegs remote starter solenoid (been sitting a while). One day the car will start every time, but then some days it wont even turn over or click.
Today I start it, pull it in the driveway. A few hours later, I go to pull it in the garage, but it wont turn over. I disconnect the battery to do a few things, go to reconnect the battery, and now the starter engages when I try to connect the neg. cable.
My guess is that the remote starter solenoid has gone bad. Any suggestions? Any way to test the solenoid?
Old Jun 20, 2004 | 11:20 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Sounds like it has gone bad.
You can test it on the car by jumping 12V to the small 'S' terminal and listen for it clicking.
Oftentimes when they go bad it is due to a failed spring inside - the spring that pulls the contacts apart when there is no power to the 'S' terminal. This will allow the contacts to stay closed when you turn the key off, letting the starter continue to spin. Also, it can engage at any time - even while driving. This happened to me once, and chewed the teeth off the starter drive gear. Luckily the flywheel sustained very little damage.
I replaced it with another generic Ford starter relay, and keep another one on hand, just in case.
Old Jun 20, 2004 | 11:22 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Sounds like your battery is low or dead. Make sure the battery is fully charged before doing anything. You solenoid probably did not, just go bad.
Old Jun 20, 2004 | 11:38 PM
onebinky's Avatar
Why would low battery charge make the starter engage without the key in the ignition? If low batt. is to blame he would have a click or nothing all the time.
May also want to check out the wiring and make sure you have no shorts. Check with a DVOM at the starter solonoid terminals to make sure that you really have no power at the small purple wire (from the ign. sw.), have 12.4v at the fat wire, and that you have no voltage drops over the starter wires or the ground. Remember that the starter grounds thru the chassis, so all the contacts between the starter carcass and the block have to be clean and free of corrosion.
Old Jun 22, 2004 | 07:27 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Anybody else?
Old Jun 22, 2004 | 11:29 PM
onebinky's Avatar
What parts of advice have you tried? The problem is either in the solonoid or the wiring.
Old Jun 23, 2004 | 07:26 AM
Dzhezkov's Avatar
Car: 88 GTA
Engine: 406ci
Transmission: Tremec 3550
It's the solenoid, the same thing happened with my remote solenoid, except mine would engage and stay engaged. I just went down to Autozone and picked up a Ford solenoid for $6.
Old Jun 24, 2004 | 05:42 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Does a Ford solenoid hook up the same way? If so, what exactly do I ask for at the store?
Old Jun 25, 2004 | 12:39 AM
Get yourself one that looks like one of these http://amkproducts.com/starter_relays.asp and you'll be all set.
Old Jun 25, 2004 | 01:41 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Mine, i believe is off of an older Mustang, early 90's i believe. Fender mounted type.
Old Jun 25, 2004 | 08:19 AM
Dzhezkov's Avatar
Car: 88 GTA
Engine: 406ci
Yep, fender mounted Ford, I believe mine was from a Mustang as well.
Old Jun 26, 2004 | 10:04 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Fnord made a few different styles, not to mention they also used a divorce solenoid/relay on jeep, dodge and a few others.
To be sure just take the old one down to any parts store and they can match it up assuming they know how to open a few boxes. They did make quite a few different ones some with 3 terminals and some HD. If you just want to make it simple tell them its for a 80 F series, 300-6. I'd stay aways from the Wells unit at ozone they seem to crap out quicker them most.
Old Jun 28, 2004 | 04:12 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Autozone was no help when I was trying to find the Ford solenoid....and I didn't feel like looking through boxes and boxes. Anybody have an exact make/model or a P/N? Thanks....
Old Jul 5, 2004 | 09:38 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
I got the ford solenoid, hooked it up, the car started. I go out 2 days later to start the car, it is doing the same thing.....not turning over. Everything is getting power, but no starter action. I've checked all the wires. Could it be the starter? Why would it start one day, but then not start another?
Old Jul 5, 2004 | 11:50 PM
onebinky's Avatar
What is the voltage on the wires while the car is cranking? If a wire has a bad connection, it can still show 12 volts without a load, but as soon as you try and pull amperage thru it the voltage will go way down. That's part of the voltage drop test I mentioned above
So you've verified that you have 12+ at the fat wire while cranking, at the small purple wire during crank, the output from the solonoid is good during crank, and the ground is good at the solonoid during crank? If so, tear the starter apart. You could have a "dead" spot on the armature, or worn brushes.
Old Jul 7, 2004 | 09:38 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Check the fat wire....12volts before and during cranking (well, turning the key I should say)...checked the purple wire once....no voltage b4 or during cranking, but then after checking fuses for the hell of it (which were all fine), it cranked up, what do ya know. But chances are, it wont crank again tomorrow, so I still have a problem. Does the fact that the purple wire didn't get get voltage mean it's a VATS problem? The motor was originally a 305TBI, now it's a 350TPI w/ a harness out of an '88 IROC...VATS should be disabled all together correct?
Old Jul 9, 2004 | 07:06 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
napa echlin part number ST81 is what i'm using.
Old Jul 26, 2004 | 06:11 AM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
I replaced the solenoid...no luck. Could it be a VATS problem? I had the ignition switch replaced not too long ago.
Blue419
Sep 10, 2015 01:03 PM
Stryker412
Sep 7, 2015 09:11 AM
Amillionoh7
Sep 5, 2015 11:44 PM
Formula_88AE
Sep 3, 2015 01:47 PM
z28guy134
Sep 1, 2015 11:50 PM
