Someone please run a few casting munbers for me.
Old Apr 21, 2001 | 01:50 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
I would but my connection is SLOW. It barely loads this page.
Anyway, off the block is GM 3970010. Years? 2 or 4 bolt or anything else you can tell me.
Heads say SN 30055 and the other SN 30061. TFS TW? G1? G2??
Old Apr 21, 2001 | 02:49 PM
87RS402's Avatar
3970010....302.....69....4...Z-28 Camaro
3970010....350...69-80...2 or 4
The heads don't even come close to any thing listed.
Old Apr 21, 2001 | 03:07 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
010 casting blocks are good high nickle content blocks and are worth keeping. Whenever I go looking for a 4" bore block to build a 350 I'll only grab 010 castings.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
junkcltr
Aug 2, 2019 11:12 PM
camaro71633
Sep 1, 2015 10:24 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
InfinityShade
Aug 22, 2015 08:00 PM
sreZ28
Aug 14, 2015 07:48 PM
