cam for 305
Old Aug 3, 2006 | 12:43 AM
  #51
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
why on earth would you bring up this thread to ask your question???????
start your own thread! or, in the very least, if you're going to make us all read through this, YOU can at least read it first, and learn from it eh?
Old Aug 3, 2006 | 10:00 AM
  #52
84 Restore's Avatar
Car: 1984 Z28 camaro HO Gun metal Gray
Engine: 305,L69 H.O. rebuilt
JUst read above
If you read my enrty above you will see the cam I used. It is rough and lumpy. It is not what I wanted. It sounds good with the exhast and headers when you get it geared up but it sucks off the line. I am going to try a stall converter to see if it helps. Like I said it sounds good doesn't do squate for performace.
Old Dec 31, 2015 | 06:18 PM
  #53
w41duvernay's Avatar
Car: 1986 Pontiac Firebird s/e
Engine: 305 Chevy
Axle/Gears: 2.77 for now
Re: cam for 305
Sirs,
Does anyone know? I just put in a Comp Cam 260H in my 86 LG4 Pontiac Firebird. Can I get away with putting in a Hypertech #12032 thermomaster chip or would I have to get a version for the HO 305 engines to make it work. Just looking for a cheap way to make sure the check engine light doesn't go off here.
Old Nov 20, 2025 | 08:05 PM
  #54
kirk35's Avatar
Car: '92 RS Heritage Edition, '91 Z28
Engine: '90 5.7, Vortec Heads
Re: cam for 305
Another vote for the Summit 1102. If you are dead set on Comp, take a look at the High Energy 252 or 260.
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
michealleger
Aug 26, 2015 03:29 PM
theurge
Aug 21, 2015 12:46 PM
