positioning the flywheel?
Old Apr 21, 2001 | 06:07 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
hi guys, i have to put a 350 in my 87 rs camaro, the engine is an ex pontiac 82 auto tranny, i'm installing on my T-5 manual set up (to replace my punny little gutless oil burner 305). my question is:
there is an extra hole on each part (crankshaft flange and flywheel) should they go aligned or opposite to each other?
i've seen all kinds of weird combinations.
thanks to all for your help
fernando.
third gen muscle power is the only thing that can match the power of flight...
Old Apr 21, 2001 | 07:02 PM
ede's Avatar
ede
if i understand what you're doing correctly, you can't use the flywheel that was in your car on the 2 piece seal 350. it sounds to me like the extra hole is for the dowel on the crank.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 21, 2001 | 08:25 PM
snakeskinner's Avatar
same here, 82 and 87 are non-compatible. Plus, the bolt patterns are designed to go on in only one way. the bolt holes will not line up any other way.
Kyle Osterholt
Okarche, Oklahoma
ASE Master Certified
86 T/A 383 TPI
89 TTA #1002 T-top/Leather
89 TTA #1358 Hardtop/Leather
80 T/A Pace Car
73 Opel GT
73 bronco
Old Apr 21, 2001 | 10:07 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
ok sorry i wasn't clear, my 305 is from a 79 oldsmobile, so the flywheel is the type for the 2 piece seal.
the new one is a 82 pontiac 350 same 2 piece seal, i mean the flange is exactly the same, it has 6 threaded holes and an extra hole threadLESS, and the flywheel has the exact same arrangement, so how do they go? those extra holes are they lined up or opposed?
thanks to all for your time.
fernando.
Old Apr 21, 2001 | 11:12 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
They should line up. The hole in the crank is supposed to contain an alignment dowel for attaching the flywheel properly.
Matt
1987 GTA L98 MD8 GW6
"Stop Lights timed for 35Mph are also timed for 70Mph"
Old Apr 22, 2001 | 09:18 AM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
the old style 2 piece seal flange on the crank is the half round and half square (i wander why that weird shape, maybe for balance)and i have never seen any dowell pin on them, and you can position your flywheel in any position you want=6/60degrees=360 because the threaded holes are perfectly symetrical i believe that the new 1 piece wich is round has the dowell pin (not my case)maybe it has something to do with internally or externally balanced engines?
i'm getting a headache.
thanks again....fernando :d
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
