Size of temp sensor hole in cylinder head?
Old Jul 28, 2004 | 11:48 AM
King Nothing's Avatar
Does anyone know the size of the hole in the cylinder heads that the coolant temperature sensor goes into? My headers are close to the sensor and I'm wanting to put a 90* fitting there to move it further away.
Any help is appreciated.
Old Jul 28, 2004 | 11:59 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I believe it's 3/8" NPT. Much older heads had 1/2" NPT.
Old Jul 29, 2004 | 05:26 PM
Vader's Avatar
The Ape is right. Pre-80's heads typically had a 1/2" NPT hole, but yours are probably 3/8" NPT.
The potential problems with installing an elbow or other fitting is that you may move the sensor out of the coolant stream, and that an elbow may protrude from the head nearly as much as the sensor.
If you don't mind altering the wiring harness a bit, you might be able to find a location on the intake or opposite head.
BTW - Where's your crown?
Old Jul 29, 2004 | 07:15 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Some of the newer t-stat housings have a bung hole for a sensor. Would this maybe be a good place for the coolant temp sensor??
Old Jul 30, 2004 | 10:31 AM
Good idea Vader. I'll try looking on the intake to see if there are any spare ports to put the sensor. I had wondered if the elbow would cause problems as the sensor wouldnt be in the direct flow of coolant.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
knight72
Aug 10, 2015 09:32 PM
