Pics of the engine. IT RUNS!!!!!!!!!
Old Jul 28, 2004 | 08:53 PM
Abubaca's Avatar
Here's the thread, no need to post twice.
Some of you were helping me with my "no firing" problem. The dizzy was not off, like we thought. I replaced the cap and rotor, which were new, and re-stuck the dizzy. BTW the dizzy was perfect, but we re-stuck it anyway. Anyhow, after that it fired! Not sure what actually did it, but hey, I'm not complaining!
It now has a SLP headers and a ZZ4 cam, as well as minor headwork and MSD superconductors. I have a Blaster and a 6A box waiting. I want to make sure all the bugs are worked out before I start adding more new stuff.
.....accessory brackets and TPI are cast grey. Valve covers and water pump are Ford red of all things! Manifold,throttle bracket, heads and both delete pulleys are aluminum. All paint is 500* Plastikote.
....also you can see the Russell wire looms and polished TPI bolt kit. Check out the heater control valve relo!
here's the link:
https://www.thirdgen.org/techbb2/sho...hreadid=252619
Caspar
Jun 19, 2016 11:19 PM
89gtaforsale
Aug 24, 2015 09:32 PM
InfinityShade
Aug 22, 2015 08:00 PM
NWAsonoma
Aug 18, 2015 05:45 PM
sreZ28
Aug 14, 2015 07:48 PM
