OEM timing
Old Jul 29, 2004 | 04:39 PM
lowbgtRS's Avatar
Car: 94 Camaro
Engine: 383 Stroker
OEM timing
How many degrees is the OEM timing? Or when the timing chain sprocket is set with the keyway at oem specs.
Old Jul 30, 2004 | 12:08 AM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
If its your average 305 or 350, it should be about 6 deg BTDC.
Old Jul 30, 2004 | 05:35 AM
ede's Avatar
ede
it helps a lot to say what car engine combo you have. you might even be able to find the info on the under hood sticker.
Old Aug 2, 2004 | 03:48 PM
lowbgtRS's Avatar
Car: 94 Camaro
Engine: 383 Stroker
Its a '76 350 block. What was oem for carb'd 350's?
Old Aug 3, 2004 | 12:01 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
0* was stock on those smogger 350s IIRC.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Out-Cast
Dec 31, 2015 04:40 PM
NBrehm
Aug 25, 2015 11:49 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
NBrehm
Aug 5, 2015 07:57 PM
