Still wont start.
Old Aug 2, 2004 | 04:59 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Still wont start.
Hi guys. So last week I had some issues with my car, no spark and no compression in cylinders 1 and 3. So I replaced the coil, module, cap, and rotor button. Also did the head gasket over the weekend. Got everything back together, put the timing mark on TDC, put on the distributor cap, ran the wires, still wont start. So, just for fun, I just went out, unplugged power to the coil and tested compression in Cylinder 1. Goodie, I have compression. Went for a second test to make sure, and now the damned thing wont even crank over. Oh yea, while I was in there, I also replaced the starter. Now its clicking, but not cranking over. This thing is driving me nuts, I'm thiiiiiiiis close to pushing it into the lake. Any ideas on where to go from here?? Thanks
Brian
Old Aug 2, 2004 | 05:00 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Battery Voltage?
Old Aug 2, 2004 | 05:03 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Transmission: 4L60
13. Just had it fully charged and tested at work. Bettery is fine.
Old Aug 3, 2004 | 12:34 AM
Slepewesel's Avatar
Car: 91 Camaro Z28
Transmission: 4L60
ITS ALIVE! Turns out I had the timing juuuust about right, just needed an extra set of hands to play with the dizzy while I cranked her over. Thanks for the help guys.
Brian
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
RS Reaper
Oct 17, 2018 07:52 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Jlanz55
Sep 29, 2015 08:55 AM
