Can I use some SB-CHEVY parts on my Olds Motor?
Old Apr 22, 2001 | 01:42 PM
uno's Avatar
uno
Hey what parts if any that fit a small block chevy, can I use on my Olds motor? i know not the water pump but what about intake manifolds and other stuff?
1989 RS with some kinda V8 Motor
400 tranny
Just underway..
1995 Red T-Top Camaro
3.73 Gear
Flomaster Cat Back
Accel 8.8 Wires
Bosch Platinum Plugs
K&N F.I.P.K.
Killer Cerwin Vega Sound System
Sony Xplode Head Unit
Old Apr 22, 2001 | 02:03 PM
82camaro's Avatar
Car: 82 camaro SC
It's a completely different design.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Apr 22, 2001 | 02:49 PM
ede's Avatar
ede
some of the bolts you have are the same size and thread pitch, but i think the length is differant. in short nothing will work or interchange.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
[This message has been edited by ede (edited April 22, 2001).]
Old Apr 22, 2001 | 10:38 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
The distributor cap and rotor and some or the other ignition parts, but basically just stuff on the outside of the engine. They don't even use the same oil filter IIRC!
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Old Apr 23, 2001 | 12:14 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
most of the ignition system will interchange along with carb and stuff, but not much else.
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
1nastygta
Aug 8, 2015 07:38 PM
