Car Wont Start, mystery cable...
Old Jul 29, 2004 | 09:41 PM
JLP's Avatar
JLP
Car: 1983 Trans Am
Engine: 305 LG4
Ok I recently took out the alternator and now the car wont start...
For some reason I have a cable that I dont know where it goes. Its attached to the positive batter terminal and its much smaller then the one that goes to the starter. Is this just a ground? Not sure where it goes....
Either way my car wont start
Old Jul 29, 2004 | 09:52 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If the cable is about a 4 gage wire and is black/red in color, it goes to the post on the back of the alternator.
P.S. I hope you were wise and put the alternator back in the car, it doesn't work too well with just a 12 volt non-charging battery.
Old Jul 29, 2004 | 11:06 PM
JLP's Avatar
JLP
Car: 1983 Trans Am
Engine: 305 LG4
k cool, I just hooked it up but still no go...
Im not totally worried I know its just something I did.
I should have said this earlier, but I also removed the heater box and never hooked up any of the wires...Its just a missing heater box. Do you need these wires for it to turn over?
Lastly, if this helps any, when I turn the key all the way the interior lights go off and then come back on when I turn the key back.
Old Jul 29, 2004 | 11:44 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Does it crank at all? Slowly? Anything?
Have you tried starting it via jumpers? Whats the volt reading on the gauge show?
Old Jul 30, 2004 | 10:30 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Reconnect all the wires that you have disconnected from the heater box removal and see if that is your problem.
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
