How can you tell if Dist. is in backwards?
Old Apr 23, 2001 | 12:41 PM
Jas89TTA's Avatar
Ok, I got my car back together and tried to fire it up last night and it would not start. The engine would turn over and at the end it would pop (backfire) Does this sound like the disturbutor is off 180*? I did have a custom chip made up and was wondering if it could be the problem. I'll beable to work on it again tomorrow was just loking on some input on what it could be. Thanks
Old Apr 23, 2001 | 12:57 PM
tpsierra's Avatar
Take out #1 plug. Rotate engine until timing marks at zero while sticking finger in SP hole, if pushing air is at TDC on compression stroke, open cap, rotor should be pointing at #1 wire, if not lift dist and rotate rotor to agree.
Old Apr 23, 2001 | 02:07 PM
Box of Rocks's Avatar
Jazz,
Look in the mirror..........
If your eyebrows have been singed off, the dist. is in 180* off.
Actually, like the man said, with the timing mark on TDC with #1 piston at the top, the rotor should point at #1 plug wire on the cap.
Good luck.
BOR
Old Apr 23, 2001 | 02:20 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
distrib is out 180 or timing is way out
prob 180 though, doesn't matter where the rotor is pointed at #1 cyl @ TDC as long as #1 plugwire is over the rotor at TDC
Old Apr 23, 2001 | 02:21 PM
Engine: 305TPI
oops, here's a link to a tutorial i wrote on setting timing and installing a distrib:
http://www.iroc-z.org/tech/distribut...ngdistrib.html
http://www.iroc-z.org/tech/distributor/settingtiming
good luck
Webmaster: www.IROC-Z.org
pjsparts
Oct 29, 2025 06:39 PM
Out-Cast
Mar 22, 2019 09:39 PM
apo_bailon15
Mar 28, 2016 05:20 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
db057
Aug 22, 2015 08:17 PM
