painting alumnium heads
Old Jul 31, 2004 | 01:08 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
can you paint alumnium heads? i dont see why you couldnt but i dont know so i decided to ask. i want mine to be black to match my block. or would that be a bad idea?
Old Jul 31, 2004 | 01:18 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Yes, but bare aluminum is cool. But the stealth factor is too.
Old Jul 31, 2004 | 01:25 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
yes it is but i want to make it all look a little more uniform. will the black paint do me any harm as far as detonation? im running a pretty high about 10.5:1 compression on pump gas and the alumnium heads will help but will that black paint hold in any heat that will cause detonation?
Old Jul 31, 2004 | 02:18 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Painting them won't make a difference. The chambers are really water cooled.
RBob.
Old Jul 31, 2004 | 02:21 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
thax, just wanted to be sure
Old Jul 31, 2004 | 02:36 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
They also radiate heat into the atmosphere.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
project89
Sep 24, 2015 06:38 AM
neekolzun
Aug 24, 2015 04:59 PM
