Why buy a cap with brass terminals?
Old Jul 31, 2004 | 08:02 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
So really cool things like this don't happen, out of the blue, while your driving down the road.
I don't know about your guys V8s, but mine doesn't run to well on seven cylinders.
Old Jul 31, 2004 | 08:07 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Weight savings.
And yup, those are definitly not brass terminals
Old Aug 1, 2004 | 09:49 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
I have found that on various vehicles that I have owned, that the caps with brass terminals don't seem to corrode like the steel terminals above...
On the brass caps, the wear is limited to what I consider normal. But there appears to be corrosion on top of the wear with steel terminals.
And...
Missing a terminal never helps deliver peak power
Old Aug 1, 2004 | 11:44 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I've seen one like that before.
Old Aug 1, 2004 | 12:33 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Also brass is a better conductor of electricity. Steel is near the bottom of the metal conductivity list.
Old Aug 1, 2004 | 01:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Those terminals are probably aluminum, not steel.
Old Aug 1, 2004 | 05:02 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
yep. they bend easier than a paper clipl
Old Aug 2, 2004 | 09:21 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
thoes are alum.
and unless you use grease on them when they're new, they'll corrode in a couple weeks of use.
Old Aug 2, 2004 | 10:59 AM
MasterEvilAce's Avatar
Re: Why buy a cap with brass terminals?
I wouldn't say that... I have a 350TPI... My friends pointed out once how the tach would constantly fluctuate, and the oil pressure bounces and such..
They were like "Wow, that's awesome" (IE: made the engine seem sort of racey)
I knew something was wrong, but I didn't care, the car drove fine, and still had tons of power
I went to see if i could get the oxygen sensor off to replace it (it's welded onto the manifold now, ).. and I reached down there.. and.. WTF?!?!? HAS THIS SPARKPLUG WIRE ALWAYS BEEN OFF?... Other than the tach, oil pressure, and a slight jerking while coasting at 30mph... You really couldn't tell anything was wrong.. Tons of power for a V7.. I just can't believe I went so long with it like that..
I connected it, and now the car is fine, idles smooth, oil pressure is constant, and seems to have gotten back some more power
Still get 12 mpg, though.. Oxygen sensor probably :-/
Old Aug 2, 2004 | 12:31 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
Re: Re: Why buy a cap with brass terminals?
Uuuhhh don't you maean *****?
Old Aug 2, 2004 | 12:40 PM
Yeah, but it gave it a weird appearance that it was tough... as in, not a luxury car, but a badass torque machine
still ran good on 7 cylinders, so it's not like it couldn't move itself or anything
Old Aug 2, 2004 | 12:55 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
dont worry..
you arnt the first one to not realize theres a plug out on a SBC.
and your friends arnt the first ones to mistake a missing cyl for a lopey cam... lol.
Old Aug 2, 2004 | 12:56 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
well mine was backfiring out the exhaust under cruise, idling much rougher than normal, and ran like crap at anything more than light acceleration.
basically, running on seven cylinders
Hotrodboba400
Dec 10, 2019 07:07 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
billybob6110
Sep 23, 2015 01:30 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
