Carb Spacer Question
Old Aug 1, 2004 | 08:00 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I've had good luck with a 1" thick 4-hole spacer under my Holley, and I'm wondering if anyone here has tried a 2" thick 4-hole spacer?
If 1" is good, is 2" better?
... Assuming that hood clearance won't be an issue.
Old Aug 1, 2004 | 08:44 PM
Conv389drv's Avatar
There's an awful lot of variation among carb spacers when it comes to power gained or lost. Basically the only way to know for sure is to try it. If it's cheap and doesn't require hood modification, then give it a shot. If you have to use a hood scoop, I'd say don't worry about it. It'd only be worth a few horsepower over the 1", not worth the hundreds of bucks for a new hood.
Old Aug 1, 2004 | 09:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup, it's a tuning aid; there's no "always right" answer, just experiment and see if it helps your particular combo. Every motor/car is different.
customblackbird
Aug 15, 2021 10:16 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
