idle problems
Old Aug 2, 2004 | 06:33 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
idle problems
I have been dealing with this idle for over a year now and i am getting so irritated by not being able to diagnos it. This is what it does.
The idle tipicaly stays around 900-1000 but every once in a while for no reason. doesn't matter how hot the car is or the outside temp. wheather doesn't affect it, open loop vs. closed loop doesn't matter, the idle will jump to about 1100-2000. now it will stay at this idle for a while, it doesn't jump around. Then a while after driving i will notice it's running fine but then it will do it again sometimes.
So heres what i have done to try and solve the problem so far...
-Replaced any questionable vaccum lines
-Replaced and adjusted TPS and IAC
-Cleaned and lubed the TB
-Added a second throttle return spring
I believe that is all. I also had a code 36 come up just recently but the MAF burnoff relays are only 6 months old so i reset the ECM and it hasn't caome up since. not sure if that helps.
I'm thinking its a vaccum leak but can't find it anywhere. please someone help me.
Old Aug 3, 2004 | 07:56 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
sounds like an intake manifold leak,spray some carb cleaner around the manifold/head mating surfaces and listen for an rpm change,remember tho,that only covers half of the possible surfaces there,the leak could be from the bottom side.
Eric
Old Aug 3, 2004 | 07:59 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
oops you are a fi/dude!
check the map sensor and maf sensor?i'm a carb guy myself
Old Aug 3, 2004 | 10:26 PM
trueburton's Avatar
well i was actually thinking it could be the intake manifold cause there is a little bit of oil in the valley where the intake meets the heads/block. It is always there, i never wiped it off cause it's hard to get at, but it should burn off if it was a previous spill or something right? if it is always there that means there is a leak right? where is the map sensor don't think i have one.
Old Sep 9, 2004 | 01:03 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
try a can of dry gas and some fuel injector cleaner in the next two tanks of gas
Eric
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
