help! my car won't fire!
Old Apr 24, 2001 | 05:22 PM
Abe65's Avatar
This morning I tried to start my car and all that happened was it kept turning over and over. I came home later and tried to start it and nothing fired. Later on I tried again and like a miracle it started. Then I shut it off. Tried to start it again and nothing. So I changed my cap and rotor. This was no help. The coil wire sparks when off the coil. I can hear the fuel pump humming so what could it be?
89 IROC L98 3.27 BW
Hypertech stage 2 chip, Airfoil, 3 inch exhaust, gutted cat and MAF screens
Old Apr 24, 2001 | 05:53 PM
CamaroZ_85's Avatar
does it alyways get spark? and not just from the coil but to the plugs?? if it always gets spark its most likely gotta be fuel related. the pump buzzes, but is it getting fuel to each cylendar?? how was it runnign before all this? throwing any codes at all? maybe a horrible vac leak, but the only way I can see that happening overnight is if you oveaheated it and warped something last time you drove it. if you are gettign spark intermittantly, then test or replace the ign module. this kind of stuff sucks, good luck
85 Z28- 350, Comp 262, Edelbrock Performer intake, Edelbrock 600 cfm carb and Edelbrock cat back, Summit headers and vette servo
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
Old Apr 24, 2001 | 06:31 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
no spark? ignition module.
take it down to a parts place and have them test it
Webmaster: www.IROC-Z.org
1992rs/ss
Jan 31, 2025 05:10 PM
TheExaminer
Aug 26, 2015 04:59 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
apie2546
Aug 10, 2015 05:43 PM
