Fusible Link
Old Aug 3, 2004 | 10:26 PM
5.8L Camaro's Avatar
Car: 1988 Camaro
Engine: 350 V-Eight
Fusible Link
How do I know if the fusible link on the starter is blown? Will it have smoked when it blew? Is it possible for the link to still work but not very well? How do I go about replacing it?
Old Aug 3, 2004 | 11:02 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Pull on the wire slowly, if it stretches it is blown. To replace it just get a new one and splice it in.
Old Aug 4, 2004 | 05:25 PM
Car: 1988 Camaro
Engine: 350 V-Eight
I did blow the link on the starter, but I kinda just pushed it together, and got power back. But whenever I go above 2k rpm's, the tach starts to fluctuate, and the engine misses but the popping sound is real muffled and quiet. The radio will also cut out and turn back on. The alarm that goes off when you leave your lights on will now go off whenever the lights are on, even if the car is running. When I put the new link in, might it fix all those problems? Or are other things broken....
Old Aug 4, 2004 | 05:48 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There should be three fusible links there at the starter solenoid. One of them goes to the fuse panel and ignition switch and the alternator.
Old Aug 4, 2004 | 07:35 PM
Car: 1988 Camaro
Engine: 350 V-Eight
I ended up having time to change the link today. It fixed everything!
Fanatic1074
Oct 3, 2022 05:57 AM
3rd gen money
Oct 11, 2019 09:57 PM
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
