How to drop gas tank
Ok, I guess my idleing problem I have been chasing for awhile is a bad fuel pump.
Reading the Chilton manual, they say I need to disconnect the shocks and lower the rear axle and also lower the exhaust. Is that really necessary?
Also, the filler tube, does it just pull out of the tank through a rubber gasket like other cars?
This sounds like quite a job
Bob
Bob
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: How to drop gas tank
Bob
Bob
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Bob
Bob
in either case, this thread should help
Thanks for the link, very helpful.
I am pretty sure the pump is bad for a few reasons. First I am sure it is original, second I have to disconnect both the tps and map sensors to get the car to idle at all. Once I have it idling that way I can move the car but as soon as I give it throttle it almost dies. Have already changed the fuel filter, read codes, changes sensors, etc.
BTW, I don't see any mention of the fuel filler tube pulling out of the tank. It does not do that? I'm used to the ones where the tube is pushed into a rubber gasket in the tank.
Bob
Bob
Got it done, pretty big job, most difficult part was getting the filler tube to come out and then go back in correctly.
The problem was the rubber hose from the pump to the metal tube, it had cracked and was pretty soft.
Thanks for the info guys, it helped a lot!
Bob
Bob
AkDrifted
Aug 17, 2015 07:45 PM
