Car Cranks But Wont Start....heres What Ive Done
Old Aug 6, 2004 | 02:24 AM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
Ok guys this is like my third time posting on this and so far all ur help is well appreciated but hasnt worked...im at a loss...car hasnt ran in a year
specs in signature
car cranks but wont start....the car was running fine one day about a year ago and then all of a sudden just wont fire up...i get it to crank..can verify fuel but get no spark
so i replaced
the ignition module(4 times now)
ignitions coil
checked all plugs..all look good
all wires are good and routed correctly
replaced cap and rotor
after doing searches..i thought it may be possible my timing is off that bad..but i never actually removed the distributor...so could it really be off just from taking cap and rotor off?
thanks for any imput...
Old Aug 6, 2004 | 02:55 AM
305PhoenixAm's Avatar
Car: 85 Trans Am
Engine: 383 TPI (Yes, TPI. Not for long though)
How long has that tank of gas been setting?
Old Aug 6, 2004 | 02:56 AM
Axle/Gears: 3:08
the fuel pressure is good.dont remember the exact number...and the gas is about a year old now...the car last started almost exactly a year ago to the day.......then the next day nothing..jsut cranking...no turn over
Old Aug 6, 2004 | 06:27 AM
ede's Avatar
ede
have you tried trouble shooting instead of random parts replacement?
Old Aug 6, 2004 | 06:29 AM
Axle/Gears: 3:08
well like i said before ive verified fuel pressure
and i held the number one spark plug boot to the header and had someone crank it to see if i got spark(by trying t view an arc....)
im not too adept with cars yet....just doing things im finding in olld posts...
any tips would be greatly appreciated..thanks
Old Aug 6, 2004 | 08:58 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Pick-Up coil in the distributor? You havent checked that and thats the only thing left in the distributor. But your going to have to remove the dis. and tear it apart.
Old Aug 6, 2004 | 09:50 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Take a plug (old or new) and just pull the easiest plug wire and stick the plug in it and have someone crank it while you ground the plug. That's the easiest way to verify spark. With a 40k gap, the spark ought to be clearly visible. It's hard for a spark to jump almost two in. out of the boot to ground! If your worried about the gas being old, poor some more in the tank and add 1/2 can of octane boost with it. Have you tried a short shot of starting fluid?
If you do, don't fire it up with fluid in case of back fire. You can set the air cleaner lid back on while you crank just in case.
If you take your ign. module to Auto Zone they will test it for free. No need to keep buying them!
Resarting an engine after a year is easy only if you give it a chance. For instance, The rings on the pistons that were at the top of the stroke might have the rings stuck in the grooves. A good shot of Rislone in each cyl. and let sit over night might be enough to free them up. (hard to start a motor with no comp.)
Old Aug 6, 2004 | 10:00 AM
MR. KIDD's Avatar
Car: 85 IROC
Engine: 406
Transmission: A4
Check the voltage at the coil does car have any anti thief devices check your pickup coil also.
MR. KIDD's Avatar
Car: 85 IROC
Engine: 406
Transmission: A4
Old Aug 6, 2004 | 10:14 AM
black92305rs's Avatar
Car: 92 RS
Transmission: th700r4
I had a similar problem, no spark and injectors would not work. After replacing the distibuter it fired right up. Check the pick up coil in the distributer.
Old Aug 6, 2004 | 10:57 AM
ede's Avatar
ede
get a noid lite and check the injector harness. you don't really check spark by seeing if it'll spark with a spark plug. buy a spark checker if you have spark there you have spark enough to fire the plug i nthe engine.
Old Aug 6, 2004 | 08:17 PM
Axle/Gears: 3:08
ok gonna go check it all out.all the things listed..got to get to autozone...ill keep ya updated....and no..no theft deterrent system and its carbureated
Old Aug 6, 2004 | 09:03 PM
ThommyDee's86Z's Avatar
Car: 86 Z28 w/ T Tops
Engine: 305 SB w/ Performer intake 3701
Transmission: 700 R4
Axle/Gears: stock
A spark tester is about $10 and you will know for sure about spark.
You can dump 1/3 a cup of gas right down the carb and you will know pretty quickly if it is bad gas or NO gas. (just stand back when you crank)
I had a new rebuilt carb that would squirt gas when the accelerator was pushed but would not squirt when cranking.
Reborn756
Sep 4, 2015 03:42 AM
TheExaminer
Aug 26, 2015 04:59 PM
Thirim
Aug 13, 2015 03:09 PM
mizz0313
Aug 12, 2015 06:45 AM
gwade12
Aug 8, 2015 08:17 AM
