What are possible causes for a repetitive squeeking coming from the wheel??
Old Apr 24, 2001 | 11:54 PM
Conv389drv's Avatar
It's been making this noise for a while now; it sounds like a wheel bearing noise coming from the front wheel (driver's side), but I jacked up the car to turn the wheel by hand, and I didn't hear anything abnormal.
There seems to be a good bit of play up and down, but it's not because of the spindle nut coming loose (it appears to be tight enough).
I've had other wheel bearings go bad before, and it's been obvious then; they get louder over time, and I can hear it grind when I turn the wheel by hand (I've replaced those).
I can't figure out what's making that frickin' squeek. Anybody have any thoughts on this???
Thanks!
Old Apr 25, 2001 | 12:06 AM
Guest
Guest
Posts: n/a
Brakes?
Backing plate rubbing on a warped rotor?
Old Apr 25, 2001 | 12:11 AM
Conv389drv's Avatar
Could be brakes, but I would think the sound would stop when I apply the brakes coasting down. It doesn't seem to make any difference whether I'm using the brakes or not.
(Whoops, this is on a '62 Bonneville btw. Guess I shoulda mentioned that earlier Drum brakes all around)
Old Apr 25, 2001 | 01:15 AM
Guest
Guest
Posts: n/a
Heh.
A squeak huh? Unusual. Check to make sure the backing plate isnt rubbing on the drum at all, and only other thing I can think of is the bearings. That is if it isnt coming from the engine
Old Apr 25, 2001 | 02:10 AM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
I had the same problem today. The noise stopped when I hit the brakes, so I didn't think that was the problem. Checked the pads, though, and that's where it was coming from. I'll be working on that tomorrow.
Old Apr 25, 2001 | 11:34 AM
Conv389drv's Avatar
Well, I might replace the bearing anyway, just to rule out that possibility.
Old Apr 25, 2001 | 02:27 PM
Xenodrgn's Avatar
I could be way off, but check and make sure that the shocks and everything like that is lubed up. Thats what it sounds like to me.
1985 Camaro SC - 2.8L, auto. Stock.
Old Apr 25, 2001 | 03:19 PM
CamaroVroom's Avatar
HEY DUDE I HAD THE SAME PROBLEM LIKE 3 MONTHS AGO...THE SAD THING IS I CAN'T REMEMBER WTF IT WAS...BUT I THINK IT WAS THE SENSOR ON THE BRAKES..BOTTOM LINE TAKE IT TO A SHOP AND HAVE THEM LOOK AT IT AND THEY WILL FIX IT...CUZ U WILL NEED NEW ROTORS AND STUFF SO GO ASAP AND GET IT DONE WIHT
1988 Camaro RS 2.8L exhaust runs about 190hp. Kills all those rice boys and euro trash cars.
(KILLS) 1987 Honda Accord LXI, 1994 Honda Accord EX, 1997 VW Jetta, 1995 Camaro Z28, 1993 Honda Prelude SI, Dodge Intrepid, 1990 Nissan 240SX, 1989 Ponitiac Firebird, 1990 Pontiac Formula Firebird
Fronzizzle
Mar 18, 2019 08:29 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
kah992
Aug 19, 2015 02:55 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
