Replaced cat and emissions went up
Old Aug 6, 2004 | 04:23 PM
RallySportin''s Avatar
Car: 92 Camaro RS
Engine: ZZ4 350 TBI
Transmission: 700-R4
I failed emissions a couple weeks ago, because of NOx. Standard was 2.2 actual was 2.37. I replaced the egr and cat less than a week ago, and failed once again today. Results:
Allowed/Actual
HC (GPM)
1.0/.66
CO (GPM)
20.0/.01
NOx (GPM)
2.2/2.76
CO2 (GPM)
NA/398.03
Does the cat need more time to be broken in, and what else can be done for this? I can scan the graphs if needed.
Old Aug 6, 2004 | 05:39 PM
Vader's Avatar
You need to cool down the combustion shambers more. Add more EGR (not easy), add alcohol to the miixture, clean the chambers before testing again to remove carbon, make sure timing is advanced correctly.
A cat converter generally doesn't need a break in, but it needs to be hot to work properly. Some of the old design cats also need an air supply to complete the NOx conversion. If you have an OEM cat and not a 3-way replacement, you need to be sure the A.I.R. system is connected and working correctly.
Old Aug 6, 2004 | 05:54 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
How long since you changed the O2 sensor?
Old Aug 6, 2004 | 09:25 PM
Car: 92 Camaro RS
Engine: ZZ4 350 TBI
Im not sure about the O2 sensor, it doesnt look to new, how much do they go for at a place like advance or autozone?
Old Aug 6, 2004 | 10:54 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Usually varies between $20-$30.
Vintageracer
Jan 10, 2020 05:33 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
nuggie
Aug 25, 2015 01:27 PM
Out-Cast
Aug 22, 2015 07:49 PM
theurge
Aug 21, 2015 12:46 PM
