Major problem, cant start car!
Old Aug 6, 2004 | 06:48 PM
JLP's Avatar
JLP
Car: 1983 Trans Am
Engine: 305 LG4
Ok, few days ago I posted that I couldnt get my car started so I tested the battery...it was completely DEAD.
So I went out and bought a new one, when I tried to install it, sparks started flying everywhere like mad on the battery terminals.
What can be wrong????
Old Aug 6, 2004 | 07:02 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Sounds like a dead short somewhere, start tracing the wires till you find it, or get someone who knows how, bad wires could burn up you car!!!
Old Aug 6, 2004 | 07:28 PM
JLP's Avatar
JLP
Car: 1983 Trans Am
Engine: 305 LG4
Ill get someone to take a look at it, but in the mean time, what should I keep an eye out for? Which wires etc...
Old Aug 6, 2004 | 11:21 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Inspect all the grounds. Start with the big 3 under the hood.
Back of head to firewall (passenger side head, its a big ground strap, about 1/2" wide)
Battery to fender (right off the neg batt cable)
Battery to engine (If you can't find this one....)
When my battery sparked like crazy, both the batt. to fender and the head to firewall were rotted out.
Old Aug 8, 2004 | 11:56 PM
Andrew89tpi's Avatar
Car: 91 camaro rs
Engine: 350tpi
Disconnect the alternator and see if it still sparks.
Old Aug 11, 2004 | 08:09 PM
JLP's Avatar
JLP
Car: 1983 Trans Am
Engine: 305 LG4
Ok, I finally figure it out.
When I removed the heater box, for some reason I had the ground wire in the "connection box" and it was aligned with a live wire... I unplugged that and everything was fine.
The alternator was OK tho:P
Thanks everyone for your help
specialized
Jun 18, 2022 09:26 AM
jharrison5
Aug 19, 2015 05:53 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
hokis
Aug 9, 2015 03:57 PM
mustangman65_79
Aug 8, 2015 12:07 PM
