what valve springs shall i use?
Old Aug 8, 2004 | 01:34 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
ive got a '79 4 bolt main 350 with 305 heads, and i just recieved a cam for it. i was told i should change out my old valve springs for this cam. my cam is the CS 268H-10. comp cams gave me a #981-16 part number and i looked it up, those springs are just the outers. are the outer springs all i need?
Old Aug 8, 2004 | 02:00 PM
ede's Avatar
ede
if that's what comp recommends that's what i'd run. i'd traqsh the factory rotaters and buy comp retainers to match the springs.
Old Aug 8, 2004 | 04:03 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
so i would be fine if i were to replace the outers and leave the inner springs alone?
Old Aug 8, 2004 | 10:20 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
981's are the outer spring, yes. They also have an inner damper (single with damper). Not really an "inner spring" just there to absorb some harmonics, much like a balancer.
Old Aug 9, 2004 | 12:42 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
good man, thanks guys ill let you know how it goes
pjsparts
Oct 29, 2025 06:39 PM
crzycamaro86
Sep 12, 2015 05:51 PM
ericjon262
Sep 11, 2015 06:07 PM
lakeffect2
Sep 7, 2015 03:52 PM
