will a stuck valve cause the engine to shake
Old Aug 8, 2004 | 09:46 PM
BOTTLEDZ28's Avatar
Transmission: A4
I just got back from the dyno to ahve some part throttle A/F runs done and they told me that the engine shakes to much at idle to 1500 when they rev it a little bit. They think it migh tbe a stuck valve since because 1: the rockers are VERY quiet. 2:the engine stumbles sometimes when I take off.3: it pops a LOT through the tailpipes.
the engine has about 40 miles on it. it is a 383 hydraulic roller setup. AFR 190 heads, harland sharp 1.5RR.
How true does this sound to you guys, Im not saying the guysat the shop dont know there $hit but I figured I would ask you guys who might have been in these shoes before.
I am gonna pull the covers and loosen them with the car idling and then tighten them back up with a 1/2 turn after 0 lash
Old Aug 8, 2004 | 09:57 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Check the timing. If you checked it, double check it.
Old Aug 8, 2004 | 10:02 PM
BOTTLEDZ28's Avatar
Transmission: A4
well, I have the timing set at 12 degrees. thats what comp cams told me to start with. my cam specs are 224/230 503/510 112LSA
Old Aug 8, 2004 | 10:08 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Try lowering the initial static timing and work from there. (I'm guessing you haven't tried any other timing settings).
Other than that, have you done a compression test? A leaking valve, whether it be stuck or not seating completely, would cause for a lower compression figure for that specific cylinder.
gta90
Sep 15, 2015 04:00 PM
backtothe80s
Sep 5, 2015 12:39 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
