Which would be a more effective place to tap oil from?
Old Apr 24, 2001 | 08:12 PM
Jester's Avatar
I need to run an oil line from the block to my turbos. My question is which tap on the block would be best? It would be easiest to run it from the fitting above the timing cover on the front of the engine. However, most of the ones I've seen either got it from the pressure sending unit above the filter, or from the one behind the manifold. Is there any real difference in oil flow, or are they all the same?
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Apr 24, 2001 | 08:35 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
They're all the same. You could also Tee into any of them such as the sending unit. It won't effect the flow.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Apr 25, 2001 | 11:00 AM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
best bet is to tee off at the pressure sending unit behind drivers head. this is coming straight from the filter, less chance of contaminating the the turbos.
85 IROC 350 11:1keith blacks,.555lift erson roller cam,1.5 crane roller rockers,edelbrock intake,holley 4150 750dbl pumper, nitrous oxide,full length heddman headers,true dual exhaust, 11"stall converter, 700R4, 3.73 locker
Old Apr 25, 2001 | 11:26 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
Go to a hospital and see if you can get your hands on one of those stainless steel stands which are used to suspend IV bags above a patient. Just attach that sucker to your antenna mount location, and hang a quart of oil from it.
Old Apr 26, 2001 | 12:05 PM
Jester's Avatar
Actually I was just thinking of running a whole seperater oil system Dale. I'd put a reserve tank under my bumper, run the drain lines to it, and use my winshield washer pump to pump the oil up through the turbos
JSP Motorsports
ICON Motorsports
Old Apr 26, 2001 | 01:06 PM
Synergy's Avatar
Now there's a great idea!
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car.
Check out our car club Truspeed
Check out the Bin Archive for all your .bin needs
Hotrodboba400
Dec 10, 2019 07:07 PM
billybob6110
Sep 23, 2015 01:30 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
dimented24x7
Sep 6, 2015 03:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
