Removing engine oil cooler
Old Aug 9, 2004 | 08:10 PM
88Z's Avatar
88Z
Car: 88 Iroc
How do you remove the engine oil cooler from the block? Does it screw off just like the filter? I've already tried that without much luck. Hopefully I'm missing something.
Old Aug 11, 2004 | 09:53 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
There are two bolts that hold the engine oil cooler -adapter- to the block. It is held on just like the oil filter adapter is, but with longer bolts. 10mm or so as I recall.
I'm not completely sure if this is what you're asking about.
If you are talking about the pot-metal adapter that allows the oil cooler hoses to attach to the same piece that the oil filter attaches to, then you need to remove the two bolts I mentioned above.
S-D
Old Aug 12, 2004 | 12:51 AM
88Z's Avatar
88Z
Car: 88 Iroc
I've since figured it out. If i would have just taken more than 2 mins to look before i posted then i could have figured it out. It turns out there's a large, thin nut sitting underneath where the oil filter screws onto the oil cooler.
Frozer!!!
Jan 19, 2024 04:55 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
Navy8125
Aug 21, 2015 09:32 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
