How can I know if it's a 350 or a 305?
Old Aug 11, 2004 | 11:29 PM
CogsRS's Avatar
Car: 87 Monte Carlo SS
Transmission: 200 4R
My car has 2 vins on it. One on the RPO sticker and the other one is on the door and the window. There was a 5.7 Tuned Port Injection badge on the back, but that is easy to put on. One vin says 5.0 one says 5.7 both are from 87s. The engine could have been swapped or the vin could have been changed or it could have been in an accident and a few things could have been changed, I dunno. I just want to know for sure. Any way i can find out without taking half the engine apart?
Old Aug 11, 2004 | 11:33 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
casting number www.mortec.com
Old Aug 11, 2004 | 11:37 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The only other way beside the casting number method that MR Leigh provided is to pull a head and measure the bore.
Old Aug 11, 2004 | 11:55 PM
CogsRS's Avatar
I know about measuring the bore, and I was hoping there was something else, cause that number is hard to see.
Old Aug 12, 2004 | 12:08 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
You can see if there are any numbers on the side of the block the flat part. Sometimes there are the last three digits or a engine size cast there. I found the 201 on mine which = 14010201...305...80-85...2
Old Aug 12, 2004 | 12:15 AM
CogsRS's Avatar
Yeah, no way Im gonna find that one either.
Old Aug 12, 2004 | 12:26 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Look on the right side of the block...there will be a cast #
it will be...627 for a 305.....638 for a 350 it's right above the knock sensor in front of the starter (it's upside down).
Old Aug 12, 2004 | 12:36 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Yeah its not hard to find. Next time you change the oil get under there with a flashlight and look.
Old Aug 12, 2004 | 12:44 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
2 simple ways, if you look at the block behind the driver's side cylinder head, the block will have a casting of either 5.0 or 5.7 liter. It is very hard to see, and usually covered with wiring harnesses, etc.
The other way is to look for a oil filter mount heat exchanger, that runs coolant from the heater hoses under the front of the oil pan to a round adapter between the oil filter and the block. All 5.7 f bodys came with these, the 5.0 s didn't.
Troy
Old Aug 12, 2004 | 01:04 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Are you saying that the oil cooler on came on L98 350's.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
