Mini Ram owners inside....
Old Apr 26, 2001 | 07:09 PM
BlueBottleJunky's Avatar
Which intake gaskets did you use? I bought my MR used and put off buying the gasket till now. Thanks.
Old Apr 26, 2001 | 07:48 PM
Steves ZZ5's Avatar
Fel-pro 1205. It's got a slightly bigger intake runner opening than the 1204. What heads are you using?
If you need a thicker gasket because of runner alignment problems, use the Mr.Gasket #106 which is .125" thick as opposed to .060" thick.
86 Trans Am WS6 Black with tinted windows, shaved door handles
ZZ4, Mini-ram, true duals, LT4 HotCam, AFR 195 heads.
***Too many other mods to mention***
"In the future, cities will become deserts,
roads will become battlefields, and the hope of mankind
will appear as a stranger"
The Road Warrior
[This message has been edited by Steves ZZ5 (edited April 26, 2001).]
Old Apr 26, 2001 | 07:52 PM
The heads are Canfield 197 cc Steve. Thanks for your quick response to my question.
Old Apr 26, 2001 | 07:53 PM
Steves ZZ5's Avatar
Do you know what the dimensions of the intake runners of your Canfield 197's are? That will be the determining factor.
I'm thinking the 1205 will be what you need.
A stock 1204 Fel-pro (most common) is 1.23" by 1.99" by .060 thick.
1.28" by 2.09" by .060" thick. are the dimensions of the Fel-pro 1205's
1.31" by 2.10" by .125" thick. are the dimensions of the Mr Gasket 106's
The 1.23"x1.99" are the dimensions you would find on a stock type head, although obviously some aftermarket heads (especially smaller CC) still retain the stock dimensions in the runner area.
I believe your Canfields are a larger runner design, so you want to MAKE SURE that you use a gasket with a larger opening to prevent reversion. Thus, I mention the use of either the 1205 Fel-pro, or 106 Mr. Gasket.
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
indygene
Sep 26, 2015 11:21 AM
09ave
Sep 7, 2015 06:03 PM
