Empty hole on rear lifter valley rail?
Old Aug 10, 2004 | 12:27 PM
Egg83's Avatar
Car: 85 Firebird
Engine: 355 Vortec TPI
Transmission: 700r4 with Pro-Built goodies
Axle/Gears: LS1 3.42 Posi Disc
Hey guys, i am assembling my 355 and i noticed a threaded hole that is about 3/8'' in diameter. This hole is empty with no plug in it. What is this hole for? I am assuming that it is part of the oil system. Shold it be plugged? Thanks, Bob
Old Aug 10, 2004 | 12:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Where is it?
Old Aug 10, 2004 | 12:43 PM
Egg83's Avatar
Car: 85 Firebird
The threaded hole is on the firewall facing rail of the lifter valley. up on top of the rail, it is oriented horizontally with the ground when installed in the car.
Old Aug 10, 2004 | 12:54 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Would this be at the very top of the block, where the intake goes, about halfway between the head decks?
Old Aug 10, 2004 | 12:58 PM
Egg83's Avatar
Car: 85 Firebird
Yes, that is exactly where it is located, thanks for all of the help RB.
Old Aug 10, 2004 | 01:04 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Oil pressure sending unit, for either the gauge or fuel pump
Old Aug 10, 2004 | 02:39 PM
Egg83's Avatar
Car: 85 Firebird
Unless i am mistaken doesnt the intake manifold cover this up once installed?
Old Aug 10, 2004 | 02:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No, it does not; it has a notch that goes around it. Otherwise it would have been very difficult for the factory to put the oil pressure sender there.
Ghettobird52
Jul 5, 2024 11:18 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Cameeeero
Aug 20, 2015 03:06 AM
