Emissions Fail
Old Apr 27, 2001 | 06:41 AM
im's Avatar
im
Emissions Fail
Hi guys,I took the emissions test the other day and failed...
Passed everything except the CO reading.
Here are the numbers:
HC=41....the limit is 68ppm
NO=134...the limit is 751ppm
CO %=1.33.the limit is .38
This is pissing me off...I have a new GM(350) 300hp crate motor(2 years old), a 1 month old brand new CATCO converter(I don`t have the air tube connected to the smog pump, all the emissions are hooked up though. My air tubes were removed a long time ago. I have heard of guys passing even with a punched converter, so I don`t think the missing air tubes should really affect me failing the test) . My timing is at 10 degrees. Did an oil change 1 month a go.Thinking of putting that Guranteed to Pass Emissions stuff in my gas tank the next time I go. Does that stuff really work??. My fuel pressure is set at 48psi. What gives ???...Any help would be appreciated. I have a Paxton supercharger also. but it is disconnected. I didn`t want to run it for the test.I have the stock setup
(air cleaner assembly with the dual air filters. After I took the test the mechanic said sometimes it is better to bring it in cold than warm up the engine(better chance of passing). I also read in the paper that if it fails at one place take it to another and it could pass. They did a test and went to 4 different places and 2 auto shops failed it and the other 2 passed it.
What gives??? any help would be appreciated
[This message has been edited by im (edited April 27, 2001).]
Old Apr 27, 2001 | 07:16 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Its just a guess, but decrease the fuel pressure and timing a bit.
92 Camaro RS LO3, 5-spd, T-tops
Performance:
SLP 1 3/4" Headers (Coated by Paul Barry Motorsports), Flowmaster Catback Exhaust, Fastchip Performance PROM, Centerforce Dual Friction Clutch, Xact 8mm wires, Open Air Element w/K&N Filter, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, Edelbrock performer intake
Old Apr 27, 2001 | 07:19 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Also after cleaning up there, run your gas guage down to 1/8 of a tank and dump a couple galls of coleman lantern fuel in.
It's gas (white gas) and runs clean.
Old Apr 27, 2001 | 08:50 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Your HCs are pretty high. The cat really needs that extra air. Turning down the fuel pressure is a good idea, too.
There are different ways of testing emissions out there. The guys who pass without all the equipment are not being subjected to the more strict methods.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere w/open diff & slipping tranny.
Old Apr 27, 2001 | 08:56 AM
Night Hawk's Avatar
I had a 1987 chev half ton with a 350 TBI. The thing had almost 300,000km on it, had the nick name 'Smokey' because it smoked so much, never did a tune up, NOTHING, just brought it in for a laugh, but decided to dump a bottle of that 'Guarunteed To Pass' stuff in the the gas tank and guess what?.....IT PASSED! Now it could be that trucks have higher failing cutoff points or something but nevertheless 'Smokey' passed because of that stuff.
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
6998poncho
Sep 25, 2015 02:56 PM
