Oil Pressure????
Old Apr 11, 2001 | 09:04 AM
CloudIROCZ28's Avatar
Oil Pressure????
I've got an oil leak in back of the filter towards the trans and engine I'm wondering what would be causing it I'm kinda pressed for time so I can't really look at it myself but it does'nt seem it's dripping from the filter but a lil ways back above the filter. So if anybody could help it would be appreciated I'm takin it in the shop today to have em diagnose the problem but how much would it cost if it was like the rear main seal that would suck money....I did just change the oil and filter and have done it right but it was leaking a lil before I changed it....
IROC-Z
G92, LB9 305 TPI, 3.23
Old Apr 11, 2001 | 12:51 PM
burnoutrpm's Avatar
could still be the oil filter re-check that, or... it could be the rear main seal. hope this isnt the situation!
89 firebird formula
356 10.5:1compression CURRENTLY DEAD!!! BEARING FAILURE!!
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
Old Apr 11, 2001 | 02:08 PM
DaveK's Avatar
<font face="Verdana, Arial" size="2">Originally posted by CloudIROCZ28:
</font>
It couldn't be running down from the oil sending unit could it? Either that of the back of the intake. Just a suggestion
Old Apr 11, 2001 | 04:27 PM
ede's Avatar
ede
my guess would be the filter, sender above the filter or the sender next to the distributor.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 12, 2001 | 08:55 AM
Thanx guys I'm taking it over to a shop today if it is the rear main seal how much would that cost??? in like estimation...
IROC-Z
Old Apr 27, 2001 | 09:21 AM
Found out it was the Intake Gaskets $20 of parts and $300 of labor (((((((
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
