Question on starter replacement
Old Aug 12, 2004 | 11:04 AM
Boss96's Avatar
I just put a new starter in, the old one looked like it had overheated, terminals on solenoid were"heat/corrosion" damaged as well as the wire coming out of the starter itself that goes to the solenoid.
Question is, car still won't start, solenoid does not "click". Would a fusible link be bad and if so where should I look for it?
Bob
Old Aug 12, 2004 | 11:26 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The fusible links are the smaller wires that go to the large terminal on the starter along with the positive batt cable.
Make suer you have the purple wire with the small terminal, connected to the "S" terminal on the solenoid, which is the one closer to the block; not the "R" terminal.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
86Base
Aug 8, 2015 01:34 PM
