new timing setup, need help!
Old Aug 12, 2004 | 11:33 AM
puckboss3's Avatar
Car: 1984 Camaro Z28
Engine: base crate 350, new GM
alright, sorry guys if this is redundant to a previous thread but i did a search of old threads and couldn't find what i needed so here goes...
i have an 84 z28 that i just completed an engine swap on from the 305 to a new gm 350 stock 250hp (money was a big issue). Now that i've got the new engine in there, i also bought a HEI distributor with the supercoil.
i installed the distr. at 0* TDC according to the timing pointer and the harmonic balancer. Now what i need to do is put the wires on the plugs and the cap.
But here's the question... how do i set the timing advance/retard with the rotor and what should it be set too? I am completely knowledgeless of the so-called "timing science". HELP!
Old Aug 12, 2004 | 11:52 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Let's get back to the basics:
Which damper did you use, the 305 one, or did the 350 come with one?
The mark on the damper pointing at the "0" could be firing position #1 or #6 - did you pull a spark plug or valve cover to know which one it is?
What carb are you using?
Why did you replace the distributor?
Old Aug 12, 2004 | 12:32 PM
puckboss3's Avatar
ok... u'll have to excuse me... i'm pretty dumb in this area. i haven't yet put the wires on the plugs cuz i dont know the order. i also don't know what a damper is... sorry. i have a 600 cfm edel carb (also not installed yet). i went with the HEI distr. cuz i was told it would be best to go with the carb and pretty much bypass the computer all together.
once again, sorry for my retardedness...
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
nuggie
Aug 25, 2015 01:27 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Street Lethal
Aug 13, 2015 08:28 PM
